Introducing the STUDER S23—and its 2026 Road Show
The newest member of the STUDER family has arrived in the form of the S23, a cylindrical grinding machine that is equally well suited for flexible HMLV (high-mix, low volume) production in smaller shops and high-volume production in large scale operations. Built with impeccable design and patented technology, it guarantees excellent accuracy and cylindricity across the entire workpiece.
The new machine is touring a handful of U.S. locations this summer and fall during the Route S23 Road Show. You can learn more and RSVP for that event, and here’s what you can expect:
Route S23 Tour Dates
- Wednesday, June 17 at Syracuse Supply in Cheektowaga, New York
- Thursday, July 9 at Methods Machine in Charlotte, North Carolina
- September 14-19 at IMTS 2026 in Chicago, Illinois
- Thursday, October 1 at Integrated Machinery Systems in Itasca, Illinois
- Wednesday, October 28 at Dynamic Machine in Detroit, Michigan
- Thursday, November 12 at Ellison Technologies in Brecksville, Ohio
What to Expect at the Road Show
- 1-day seminar at each location
- Machine demos
- Guest speakers
S23 Key Specs
- Distance between centers: 650 / 1000 mm (25.6” / 39.4”)
- Center height: 175 mm (6.9”)
- Maximum workpiece weight: 120 kg (264 lbs)
S23 Key Features
- Internal and external grinding in a single setup
- Selectable wheelhead
- C-axis for out-of-round and thread grinding
- Mineral cast machine base, machine bed Granitan® S103
About that Granitan base:
Our proprietary technology starts with a mixture of selected aggregates and epoxy resin, which is processed using a cold-casting method and cures within a day to form a highly stable machine base. As a result, STUDER shops enjoy damping properties that are 6 to 8 times better, thermal stability that brings higher surface quality and a sustainable, energy-efficient manufacturing process.
Software and Operating System
StuderWIN and C.O.R.E. team up to bring industry-leading capability and ease of use to high-precision cylindrical grinding. Expect quick and easy programming of complex processes, backed by over a century of grinding history, and technology that feels both groundbreaking and familiar all at once. It’s a perfect fit for the modern machinist.
Completely Future-Forward
Inside the S23 footprint are features and components that are beautifully designed and perfectly executed. From automation readiness to SmartJet™ coolant supply to the famous dresser, tailstock, workhead, internal grinding spindle and dressing spindles, this is a machine that you’ll be able to count on not just for years, but for decades to come.
Claim your S23 today!
Talk to your local UNITED GRINDING North America dealer about the latest STUDER offering, and don’t forget to track it down at the Route S23 Road Show, coming to a showroom (and massive Chicago trade show) near you.
